I'm not able to set my timing properly and I'm pretty sure it's due to misadjusted TPS because when I jumper the connections, I have no change in timing or idle.
I've read the write ups and watched some videos but still can't figure it out. I can't really even determine where the fealer gauges go. I figure this should be a relatively easy adjustment if you know what you're doing. Can anyone help me out? I can drive to you with maybe a 12 pack in hand. The closer to Golden the better. I have a timing gun.
Thanks!
Thanks!
