Does anyone know what is needed and where to get the hardware to build a tank and hose set up for airing up tires? My brother is building up his f350 and it calls for 80 psi in the tires. He wants to air down but doesn't want to spend an hour airing back up after a long weekend and just wanting to get home as soon as possible. He is also open to buying a used tank and multi hose setup if available. He has an RTT and rolls pretty heavy with too much "just in case" stuff.
He is considering using two harbor freight high flow pumps and making a two tire hose system as an alternative to a pressure tank.
