I kinda want an Arrow Yagi now.
Grr....
I wonder what the hell is up with my crap then.
I must really be in a bad spot... I still haven't done the 100Hz tone thing..
I'll bring this over to your house some time... if it can hit the .310 and your crap can't, well there you go we've isolated the issue..![]()
pics of the antenna!
I need some input here.... do you HAM guys thing it would be OK to put a threaded joint like I did for the bottom part on the main part of the antenna to make it break down a little bit more? My only concerns are that the threaded portion is tapered so over time the overall length of the radiating element may get a bit shorter.... that and maybe the union is not cylindrical so maybe it'd make it radiate funky.
What do you guys think?
EDIT: I just reread my thread and realized that this was one of the first questions I asked!!! Sorry!
I coiled the coax about 5 times near the connector.
I'll look for a ferrite snap on thinggie!
Thanks for the feedback! and it's nice to see you on here Keith!
Slight differences in OAL and diameter aren't going to make big changes in its resonance. [/QUOTE said:FWIW, during construction of mine we put in a small screw on the short end to fine tune the copper j-pole. Additionally, the number of coax coils, diameter and location/orientation at the bottom of the "J" made differences in the impedance. We tuned it for the center of the 2-m band at 50 ohms. Antenna analyzer was MFJ-259B, I believe. Unfortunately I don't remember the ranges of these changes but I do remember the differences were enough for us to pursue changes.
Does 531 have multiple voting receivers?The Broomfield machine is 145.310-, 100Hz tone. It's a RX-only for the system, so if your shadow causes your reception to be scratchy then it won't help (it does not retransmit 145.310, just listens to 144.710). It's job is to help primarily Boulder hams when they TX to get into the machine.
