ScaldedDog
My 4Runner sat for the last 5+ months, but ran fine on a short test drive around the neighborhood the other day. Get to Moab today and it would barely idle when I went to take it off the trailer, and mildly backfired a time or two when applying throttle at idle. Seems to run fine when on the throttle, and idled OK once or twice this evening.
What I've done:
1) Disconnected the cold start injector connector, with little or no change. It *seems* like it's idling rich, so I suppose the CSI could be leaking. Haven't been able to clamp off the fuel supply to the CSI yet.
2) Looked at the volume air flow flap with the air cleaner off. When idling poorly the flap oscillates slightly in time with the engine lope. Open the flap with my finger a little and the idle smooths right out. Apply throttle and flap opens more and the engine runs fine. Is this oscillation a cause of the slow lopey idle, or an effect?
The other thing to know is that I last put gas in it in August, and the fuel in it then was a month old, or older. (Yeah, I know, I need to wheel more...)
Thoughts? I'm thinking I'll throw a bottle or two of HEET or Seafoam (or HEET and Seafoam?) in it, figuring that can't hurt. Not sure what else to try at this point.
Mark
What I've done:
Mark
