kvanoort
0
Free Parts - New & Used
I HAVE UPDATED THIS POSTING TO IDENTIFY THE PARTS THAT PEOPLE HAVE DIBS ON. Last Updated on 9-16-08
I'm cleaning out the garage today and realize I don't have enough room to keep all the FJ40 parts I've accumulated. So if anybody wants to come get any or all of this stuff, here's what I have:
USED PARTS
1974 F block - good candidate for a rebuild - It's a transition motor ('74 1/2) with the oil filter on the block.
3 cylinder heads
2 oil pans - [Rogue Leader]
1 F crank
5 F pistons and connecting rods
lifters
F side cover
2F side cover sandblasted and painted (like new) - [Ige]
F valve covers
2 radiators
F metal fan
'72 gas tank (has a few pin holes from rust on bottom)
3 distributors
F motor mounts
2F intake and exhaust manifold - [Ige]
2F air rail
crank pulleys
head bolts
3 speed clutch & pressure plate - used but in good condition
4 speed clutch & pressure plate - used but in good condition
2F oil pump
starter
FJ60 ignition coil
'72 OEM air filter - still good I think
2 - Goodyear Wrangler AT/S tires P235/75R15 - I was holding onto them as spares
NEW PARTS
2F set of Clevite bearings - .25mm
ITM oil pump
4 - 25mm freeze plugs
2 - 24mm freeze plugs
5 - 50mm freeze plugs
2F set of Dura-bond cam bearings
2F set of Clevite main bearings - .25mm
2F ITM Engine Gasket kit - If you're rebuilding a 2F and don't mind aftermarket parts this stuff is for you. - [Jeff Zepp]
2F OEM exhaust gasket - [Ige]
2F OEM side cover gasket - [Ige]
'72 OEM fuel filter
You get the idea - lots of stuff that I think is worth keeping but I just don't have the room for it all in my garage.
It would be great if someone could stockpile the parts for club members as I'm sure these parts are going to be harder and harder to find in the future.
Kent
USED PARTS
3 cylinder heads
1 F crank
lifters
F side cover
F valve covers
2 radiators
F metal fan
3 distributors
F motor mounts
2F air rail
crank pulleys
head bolts
2F oil pump
starter
FJ60 ignition coil
NEW PARTS
ITM oil pump
'72 OEM fuel filter
Kent
