Looking front & rear 60 Series driveshafts.
Front:
84-90 needed. These will have the single u-joint on either end. The early ones have a double cardan at the t-case end and a single u-joint at the diff, and I don't want that.
Rear:
81-84 driveshaft needed. These will be the longer ones. 84-90 rear driveshafts are shorter since the transmission spacer pushes the transfer case back further, I don't need that.
I will have Bill's rebuild whatever I get to work for my weird setup, so it's ok if whatever you've got has blown u-joints or whatever else. As long as the tubes are good, I'm game. Anybody have front or rear they can bring to the expo?
Front:
Rear:
