FJ60 clutch, transmission jack - needed?
den
I am starting a transmission remove/replace and don't want to find out after the fact that I have the wrong tools. Should I use one? Is there a rental place around that has one? Getting started this afternoon.
i've always used cherry pickers, but in an fj60, you don't get much room to work, so it requires three people.
I used two floor jacks and a home made "cradle" from an old steel framed creeper. The allowed me to raise and lower the tranny and case with only help from the wife.
A couple of other tips:
Get some 3-4 inch bolts the same size as the tranny mounting bolts. Cut the heads off and use them as studs to guide the tranny back in.
Pilot bearing removal tool
http://forum.ih8mud.com/showthread.php?t=66170\
Worked like a charm.
BTW, I have the cradle, tranny studs and pilot bearing removal tool I made if you want to borrow them.
den
Thanks for the offer! I got the shift boots, handles and inspection cover off last night. I'll get the rest ready tonight and see how it goes. I had already bought a transmission jack adapter for my floor jack, so I'm going to try it first.
