Also the Edgestar and Whynter do have the preferred Danfoss compressor..
They all use the Danfoss except the Engel. My new ARB fridge has the Danfoss. Even the National Luna has it.
Edit: Just to be clear, I'm sure the back of my truck gets upwards of 150 degrees sometimes and I want the cooler to be able to keep freezing temps plugged in all the time. If this isn't realistic with the ARB either then please let me know before I end up buying another one that I can't use. If something breaks then I'm not that concerned as there is a warranty on it, but I want to make sure that it can handle those temps and constant running when nothing is broken.
You are purchasing an unopened in original packaging, ARB Fridge Freezer Model # 10800472 47 Litres (50 quarts).
ARB fridge freezers are the ideal way to keep your food and beverages chilled or frozen on your 4x4 adventures, regardless of ambient conditions. Not to be confused with less effective 12 volt ‘coolers’, the ARB unit is a true refrigerator/freezer. Own one and you’ll never again find your lunch water- logged by shifting ice, and there’ll always be a cold drink on hand during the sweltering summer months. Two separate power cords are included, one for AC operation (120 volt) at home, and one for DC operation (12/24 volt) in your vehicle. The all-new 50 qt model is able to maintain sub-freezing temperatures in 90° F heat, while only drawing 0.87 amps per hour from a 12 volt power source… that’s less than a single headlamp draws!
A clothed snowman melts slower than a naked one.
confirmed
In the 80 °F (25 °C) San Francisco summer heat, the naked snowman melted considerably faster than the clothed snowman. The clothes on the snowman protected it from the heat and acted as insulation to help keep the temperature of the snow from rising.
