The drums get hot with fully loaded travel or unloaded street driving. I daily the 60 so I've been checking every time when I get out of the truck. When they're hot I've jacked them up and it's difficult to rotate the tire - it definitely doesn't spin freely. The pedal feel also gets more stiff when the brakes are hot. Feels like I could stop on a dime haha! Both of those two scenarios - tire free spin and pedal feel - happen after the brakes cool down, too. I'm using "hot" as a way of knowing the brakes have over-adjusted.
Early 60s like my 1982 have a very basic PV attached to the brake booster that cannot be independently bled. It is not load-sensing and it's not on the rear axle. The axle-mounted, load-sensing PV was at least on 62s and possible post-1985 60s. The false check valve theory is interesting though. I'm going to back off the adjusters and then not use the hand brake at all for several days or even a week. If they're still getting hot I'll know the issue is pneumatic and not mechanical. If they remain cool, I'll be looking back at the parking brake/adjuster wheel setup. I've already been pretty sparing in how often I use the hand brake and how far I pull it up since this started happening, but having driven only manual transmission vehicles since 2001, I'm very much in the habit of using the hand brake every time I get out of the truck.
Other brake work done in the past year:
New 60 Series Aisin MC (4/2023)
Tested and verified original brake booster (4/2023)
Verified booster pushrod adjustment (4/2023)
All new brake soft lines (7/2022)
New/reman calipers (7/2022)
New Advics pads (7/2022)
New Toyota rotors (5/2023)
Pedal adjustment per FSM (7/2022)
Flush & fill with DOT4 fluid about 3 times in the past year
The only things I haven't changed are the proportioning valve, the booster (which was verified good), and the hard lines. I could throw a Wilwood manually adjustable PV at the situation, but I want to figure out exactly where the problem lies before throwing more parts and money at solutions that may not work. Or at least get closer to having a suspicion about the root cause of the problem.
