60 has horrible death wobble. occurs about 35+ mph. sometimes a bump starts it, sometimes it just happens. 83 fj60 wtih 33" bfg mt's, all pro hi steer, fj80 ends in custom tubes (been on approx 6 months) with 4x4labs adapters for the drag link side, i do have an aftermarket steering stabilizer that was off and i put back on, 5" alcan lift sua.
this is a new symptom from the last time it was wheeled (a friend wheeled it, but i drove it home about 40 minutes at highway speeds with no issues). since then, i've adjusted the drag link, changed one front axle seal and rotated the tires, now it's got d.w.
it's not a stabilizer issue because while it did have one, it fell off months ago and i've never put it back on...had no issues. put it on today, still have d.w. bot with and without it.
i put the tires back to their original locations...still d.w.
checked alignment, appears good.
tie rod ends are fine, drag link ends have the barely noticeable play in the threads (barely enough that you question if there is play, so i put new ends on, still the faintest of play...could this be it?)
i pulled the side that i'd done the seal on even though spinning the tire showed nothing abnormal, reassembled it and i still have no indication of problems except death wobble.
spring bushings look good, shackles look good, springs look good...wtf?
