Hey group, just wanted to put it out there I have a 4’x4’ CNC plasma and metal on hand.... if you need parts cut (I cut art as well). Trying to keep my machine busy anyway I can, located in Highlands Ranch. Please send message, thanks!
The compressor is quiet as advertised, plenty of air to run a plasma torch. I’d probably want more air if running big air tools all the time. It’s a well built sturdy unit. The only thing I notice is it turns on kind of hard, not sure what can be done about it... Maybe I can add or change capacitor. I’ve read some of the early ones had faulty capacitors, other issues. My only other concern is starting it if it’s extremely cold or frozen but that’s rare inside my garage. I expect it to last me 3-5 years at a minimum with regular use.Out of curiosity, how do you like that scroll compressor? I've been planning to buy one when our garage is done some day, but am basing that solely on what they say about it on the website. Is it as nice as they claim?
Also, how clean of lines does plasma cut?
Cost depends, the main variable is the material. 10 gauge metal costs 2x what 14 gauge metal does, for example.Any thoughts on costing? What are the material/thickness limitations? Sounds very cool!
Yeah if it has measurements in it, shouldn’t be a problem.Can you give a quote based off of a cad file or dwg?
This is right off the table, no clean up with book settings. Sometimes the cut might have a very slight sawtooth where the axis speed is changing, but overall it cuts very nOut of curiosity, how do you like that scroll compressor? I've been planning to buy one when our garage is done some day, but am basing that solely on what they say about it on the website. Is it as nice as they claim?
Plasma cuts pretty clean when travel speed is consistent and correct for the amps/thickness, the air stream is bone dry, and it’s real nice on water tables where the backside stays cooler/avoids burning up fine details/corners.Out of curiosity, how do you like that scroll compressor? I've been planning to buy one when our garage is done some day, but am basing that solely on what they say about it on the website. Is it as nice as they claim?
Yeah seems to hold true. The Hypertherm book settings usually result in good cuts. I have a water table with good product in it. My air is really dry, I keep air tank drained and have a big desiccant system.... I’m going to add a water drop right before and after the filter system so I can always be sure of moisture content.Plasma cuts pretty clean when travel speed is consistent and correct for the amps/thickness, the air stream is bone dry, and it’s real nice on water tables where the backside stays cooler/avoids burning up fine details/corners.
Oh wow, that is fantastic! Nice work! Now you have me trying to rack my brain on something I need cut
Man if you posted this about a month ago I would have had a ton of work for you to do. I ended up doing it by hand, but I would have loved to have it cnc'd.
