Do you mean like 4 pin tow connector? Pretty sure a yes. I may pay $3 to run in and make sure axle is still there this afternoon before we commit to bringing enough tools and a trailer up to pull it tomorrow.Happen to notice any factory trailer light connectors? I might run up there today for one unless someone else is already going. Have to figure out if 1999/2000 would even work on a 2006. Anyone know?
I pulled some nicer lexus switch panels for the rear doors, but had to reuse my LC switches since the LX ones are auto in the rear. So if anyone needs rear LX switches I got you.@Inukshuk I think the factory trailer controller may not be worth messing with. IIRC they fail commonly and folks install aftermarket controllers in their place (mine has failed and this is my plan).
I don't think I can get there anytime soon but be sure to grab all the door and window switches you can find and have fun!
I'd grab the ECU if they let you have it... would be nice for testing, might be good for the retrofit if you can get all the wiring. I understand the ECU is super reliable and almost never fails.I pulled some nicer lexus switch panels for the rear doors, but had to reuse my LC switches since the LX ones are auto in the rear. So if anyone needs rear LX switches I got you.
Andy, any thoughts on the locker ECU?
It is almost a steal at $102! Considering I could probably turn around and sell it on Mud for quite a bit more than that. However, I would much rather have a 100 series with ATRAC and a factory rear locker for a few hundred bucks and my time.Good job you guys! Awesome find! What did you pay for the axle?
