Hi Jeff, Just curious as to why you discourage SOA'ing the rear?
The suspension system is just that, a system. Modifying one part of it without engineering the rest of it is asking for trouble. Just like I've seen many bad V8 conversions and a few good ones, I've seen a lot of badly done spring overs, and a fair number of broken pinions and 40s that can hardly be driven on the road. I'm sure Kevin has too. I've seen a lot of S shaped stock spring packs, and broken leaves too. At a minimum, you'll be increasing your caster angle and thus increasing understeer.
Also, was planning on using the same style as woody on IH8MUD. I would be building it. (
http://www.ih8mud.com/tech/woody/wrap.html)
That looks like a decent design. Obviously it was before he went coil-over several years ago. All the good ones I've seen use heim joints so the bushings don't limit articulation.
However, the problem you're writing about is bagged rear springs, and there are other ways of addressing the problem. Other approaches to solve that problem are less costly and would require less time, money, work and engineering.
If you want to see a well engineered and executed sprung-over 40, take a look at Dave Brown's "Red Fox". He's using custom perches up front on his S/R (normally I'm not a big fan of S/Rs but the way he did his is the proper way to do it). You might also want to chat with Joe Calleja at CTS in Aspen Park; he's a Rising Sun member, TLCA member and has done a lot of spring overs on customer's 40s. (303) 838-4772
Best of luck and happy cruisin'!
