I really like looking at pictures of 80's.. . great stuff!
yours especiallyI really like looking at pictures of 80's.. . great stuff!
For sure! I just got my rear driveshaft back from Bill’s Englewood yesterday. I had a pretty bad vibration on the way home from the run. I must’ve got caught up on a rock (boulder) on bowling ball hill and put a good dent in the shaft (probably knocked a weight off too).Pics don't do that trail justice, that trail is a lot harder than it looks.
Scott, it really doesn’t take much of a dent in a driveshaft to create the vibration you noticed. Did you simply have the shaft retubed and if so, what did it run you?For sure! I just got my rear driveshaft back from Bill’s Englewood yesterday. I had a pretty bad vibration on the way home from the run. I must’ve got caught up on a rock (boulder) on bowling ball hill and put a good dent in the shaft (probably knocked a weight off too).
I’m good on that trail for a while. I think 35s should probably be the minimum tire size.
OEM joints? If so, were they crazy expensive?I had Bill's re-tube the shaft and do new ujoints. It was $397 before taxes.
And did it?I already had a slight vibration (prior to the 80s only run) from 45-50 mph so I was hoping the complete rebuild would take care of that too.
I don’t know. I just installed it this morning but I only had time to take it around the block.And did it?
