• RS MAY CLUB MEETING
For Sale 80 series radiator
White Stripe
Milky way galaxy
I have a aluminum 3 row radiator I'm selling I was using on my LS swap with the 5.3 liter v8. I recently upgraded to a 6 liter v8 and also to a 4 row radiator so I'm selling the 3 row. Asking 50.00. PM me if interested. It's the radiator on the bottom of the picture.
What temps where you seeing w/ the 3row??
Mine is running hot, and was thinking 4 but the price for your 3 row is nice...
Does this works with the existing 80 radiator brackets/mounts or require fabrication?
Is it set up for the stock transmission cooler that attaches on the front?
How long did you run it? Was it new when you put installed it?
I'm interested in this, but only if it's a direct swap for a stock radiator.
White Stripe
Milky way galaxy
I have a 92 fj80 that this 3 core was in with my 5.3 swap. I upgraded to a 4 core when I upgraded to a 6.0. This one fit the original mounts. It does not have the internal transmission cooler. I believe its intended for a non us diesel 80 series. I ran it for about 2 years and used toyota pink coolant. It was new before I installed it. I had to mess with my fan shroud upper mounts to make the fan shroud fit.
OK, thanks. Sorry, I'm going to pass on this one.
