I am happy to help anyone with park brake adjustment.
I have tried all that bellcrank nonsense. Makes no difference if your bellcrank is working. (Many in rust areas have seized bellcranks)
I loosen the adjusting nut, get the wheels off, and adjust the stars. Can also remove the calipers or just pull the pads to remove any rub. After a few times you can differentiate the rub of pads vs shoes.
I have installed "extended dogbones". The extended dog bones bring the fixed portion of the pad closer to the drum. That allows much more of the shoe to contact the drum. They work! I ordered a bunch for a better price. They were under $20 each. I have three sets here in Denver. Free to first come first served!
I have also seriously thought about the Superior Engineering kit.
@Hulk if you order, lets get a few and share shipping from AU.
OTOH seems like this would be easy enough for us to design our own, use send-cut-send (or envision fabrication) and make a grip domestically! I would never suggest "copying" if it was domestically available. Maybe
@nakman could become a domestic dealer - but I fear the product liability issue.
I also tell people that you don’t have to yank the park brake. Just gently pull on it until it’s set.
and this!
Procedure when parking:
- Get your truck to settle and stay still in neutral with no brakes as best as possible. Flat area, valley, top of a hill, against a rock or ledge. Avoid on a hill if at all possible.
- Gently pull the handle, clicking away till truck stays put. Sometimes it needs to roll a few inches to grab.
- Then press the foot brake again and put into park.
- Now you are resting against terrain, and parking brake is holding, and the parking pawl inside the transmission is redundant.
Ready to start again? Foot on brake. Gently press button as you gently pull up handle and it will softly release the park brake. Keep foot on brake. Shift into gear. All smooth, no clunks or lurches.
