Boulder Cruiser
Alright so I’ve done some searching and found some info but I have a pretty unique situation and wondering if you guys can help me figure this out. It’s kind of driving me crazy.
85 fj60 Cummins R2.8 H55F and split T-case.
I have a bad vibration starting at the top of 3rd gear, when I put it in 4th the vibration gets 10x worse and shakes the whole truck. I can feel it in the seat, pedal, wheel, mirrors shake, etc. 5th is the same. If I stay out of boost it’s fine.
It’s a strong rotational vibration. If I floor it through 4th and 5th the vibration is not as bad. Driving uphill it gets really bad. Coasting it goes away.
I pulled the rear driveshaft assuming I needed Ujoints. NO change. Ujoints have about 4k miles, along with a balance. The T-case was removed and inspected around the same time.
No play anywhere that I can feel. I put the truck on the 2 post put it in 4th and ran it. At a certain RPM (22-2300) I hear a nasty grinding noise, it comes and goes, then stays for awhile even while coasting and sounds slightly worse actually during decel. I have a video but don’t know how to post it.
So now I’m thinking rear output bearing BUT wouldn’t it have changed or gone away with the driveshaft out? I drained the gear oil and nothing but a little fine material on the magnet, the oil is shimmery but no larger pieces.
Any help or ideas would be much appreciated! I’m kinda stumped and don’t want to just throw money at it.
