It is three on the floor. I don't think this ever had a column shifter.
Yes! The mighty 3FE!!Not too much to add to this other than I had an H42 behind the 3FE in my 80 series for a while. It scooted along pretty good and was so much more enjoyable driving around town. I bet running one in a 40 series will be awesome!
I don’t know if you’re interested in keeping the column shifter? But there’s an adapter that bolts on top of the 4-spd and allows you to keep the column shifter and not cut a hole in the floor.
Listed here for sale:
For Sale - 4 speed column shift adapter
This adapter allows pre-1972 cruiser owners with the stock column shift system able to keep that shifting system while still upgrading to the newer H42 4 speed transmission. A real win! This adapter easily mounts to the 4 speed. A shifter linkage needs modification as well as raising the...forum.ih8mud.com
That's why you don't grind them off.Grinding rivets off is a PITA.
