2F voltage regulator - need today if possible!
Looking to pick up a voltage regulator for a 2F alternator today if possible - see photo below for example. Parts stores don’t have them. D&D doesn’t have one and is 4-5 days out on ordering one.
I have a low voltage/no charge/low charge issue that I’ve chased upstream to the engine bay - it can only be one a few things. If a replacement VR doesn’t do the trick at least I’d have a spare. Thanks y’all!
The voltage regulator is internal to the alternator, is it not?
I was wondering about a clarification, too. Internal on a 3FE I think, external on 2F?
Both external but attached on top of the alternator as far as I’ve seen. Not like a 40 where it’s offboard. The 3FE VR is just clocked differently than the 2F, but it should still mount up to the 2F alt just fine.
This is a 2F alt. On the 3FE alts I’ve Seen, the VR is closer to (and interferes with) that coolant hose in the background. Same VR, same screw locations, just different clocking.
Jim, I'm not sure what 3FE alts you have seen with external VRs but the OEM 3FE alt does have an internal VR. Double checked my FSM to be sure but they are definitely internal.
I stand corrected. The 3-4 I've seen were maybe anomalies, or else Toyota had made some mid-model micro changes (as they sometimes did).
Still in search of a 2F VR in any case!
bvb
0
2F is a screwed on regulator ( square block on the side), 3F has a internal regulator requiring removal of the rear case to replace the regulator.
bvb
0
iMO: More often than not the brushes wear down and need replaced before regulators quit working. Good time foe a inspection.😜
simps80
Arvada, CO
I bought this nib oem external for one of the fj40s don’t remember which one…
You can buy it if you want but don’t think it is what you need
But iirc 1979 and up 2f was internally regulated
And certainly all 3f were.
Also like Bill said
The problems I have chased were never the external VR
Which is why I still have this new in box oem VR
bvb
0
2F, 3F and 1FZ all “IC” regulated(integrated circuit) alts.
Thanks for the clarification @bvb!
Since it was rebuilt last year I did not suspect brushes. I called D and D and they called me back - the guy scrounged up a VR. Got up there this afternoon and it works!
Another win for D & D Auto Electric in Wheat Ridge.
@simps80 maybe my nomenclature is off. The thing I replaced with Doug at D&D is this piece on top, the “S L F” piece.
The ones that I have seen that I erroneously thought were 3FE alts were nearly the same, but that piece was clocked differently. The green connector on the back of mine has two contacts, whereas the differenly-clocked ones had three. Not sure what those came out of. Maybe 1985-1987 60s after the mid-model tweaks.
