You are not fully desmogged. Why do you have spaghetti going to the vsv? I would bag that little box entirely
My thoughts too, but I'm still not sure what to re-route and what I can eliminate.
If I'm understanding it correctly, I think that i can run a vacuum line from the choke breaker/carb diaphragm down to the inlet below on the DS throttle body, which should give full vacuum.
Eliminate the lines from the gas filter on the manifold.
disconnect the charcoal canister tube from the VSV and connect it to the air filter housing near the carb.
Sound like it would work?
