After much debate, I've decided to part with my 1989 FJ62. I've got too many projects going and not enough time. This rig is in excellent mechanical shape and would be a great candidate for a full restoration. The rig has 208,000 and the motor has 212,000.
I've done a bunch of stuff to it over the last couple years. Here is a short list:
Motor reseal - no leaks!
Cap/Rotor/Wires/Plugs
Fresh oil change with Rotella T6 Synthetic 5W-40 and Toyota oil filter.
Front hub/birf rebuild with new bearings and seals. New TRE's.
New brakes, including rotors, pads, drums, shoes. Did the 3rd Gen 4runner caliber upgrade.
New exhaust from cat back.
New Hankook Dynapro ATM 31/10.5r15.
Has been de-smogged but I have all the parts to reinstall.
New windshield.
Carpets have been power washed and the seat fabric is in great shape. Dash is cracked.
Installed heat and sound insulation on the floor boards.
Previous owner used bondo to cover surface rust around the rear window and the right rear quarter (looks poor).
There are several small dents that can be repaired with PDR but there is bad dent in on the right side rocker panel.
I'm looking for $10k. I'm in Monument. Thanks. Doug
New windshield.
