Expo Portal Ham Radio Net - 19 FEB 2008 @ 19:00 PST - GUEST SPEAKER
Chino Valley, AZ.
On the Western Reflector node #9251
Topic is: ARES/RACES
Guest Speaker Lloyd Halgunseth, WA6ZZJ - District Emergency Coordinator and RACES Radio Officer from Yavapai County, AZ. will be joining us to educate/inform us on ARES/RACES.
http://k7yca.org/
Please sign up below!
Mark - KE7IXX
RicardoJM
Centennial, CO
I'll be dialing up the Western Reflector (node #9251) for the net. I have access to a couple of repeaters that are IRLP enabled. The first one is open to the public and the second one is for members of RMRL. As this is not a scheduled event on either of these repeaters, there may be people already using them at the time we would like to dial into the Expo Portal Net. This was what happened in December and so we were about 10 minutes late in getting in. With access to two repeaters, we'll try one and if it is busy fail over to the second.
At about 7:55 (MST) I'll dial up the reflector on 146.805 (pl 186.2), if the node is busy I'll move over to 145.340 (pl 103.5) to dial up the reflector. If both repeaters are in use, we can all touch base on the 145.145 (pl 107.2) and figure out the next steps.
RicardoJM
Centennial, CO
There seems to be an issue with the IRLP note on 148.805, therefore I will be bringing the net up on 145.340 (pl 103.5).
