• AUGUST 2026 CLUB MEETING: NEW LOCATION + EARLY START TIME
    Hi Guest: The next RS meeting will be Wednesday, Aug. 5, 2026 at Fairmount Park in Golden.
    • Location: the August meeting will be held outdoors at Fairmount Park in Golden.
2005 PJ Trailers 20' Gooseneck Lo-Pro Equipment Hauler Revamp
Brucker
My trusty old trailer hasn't been so trustworthy lately. Besides the original decking failing apart, the fenders are both smashed, the paint is scratched and faded, and worst of all, some of the lights aren't functional and the wiring as of late has been giving us some issues. None of this comes as a surprise as we maintain the bearings, jack, and tires religiously, but honestly haven't done much to it otherwise since we acquired it back in 2010. And everything we did was immediately after purchasing it. Things like adding an aluminum tool box to the top of the neck, adding mounts for stabilizing corner jacks, and reinforcing the receiver mount at the front of the trailer so my receiver mounted winch could safely pull from it. But everything is is pretty much original, even the decking. With the items needing attention adding up, it is time to take it out of service for a couple weeks and give it a good make over.
Here is the trailer in question:
The fenders:
The front receiver hitch with winch mounted in it and the aluminum toolbox:
The stabilizing corner jack mounts:
The the old decking not holding up too well anymore...
Plans include all new wiring, led lights, new wood and metal decking, new fenders, a couple new D rings welded in place, and everything will get a fresh coat of paint and safety stickers.
Brucker
I have a client that is a major lumber distributor for local lumber yards and places like Home Depot and Lowes. Just so happens that they offered me the employee discount on some very nice #1 KDAT (kiln dried after pressure treatment) 2x6 and 2x8 twenty footers. How could a guy say no to over 50% off retail??? So I went and picked them up earlier this week. I will be using this lumber plus some sticks of metal tubing to create the new deck floor. I haul some heavier equipment that I would like to ride on metal that won't have the flex the wood can when point loaded.
Then I raided the storage connex and pulled out a couple rolls of new trailer wiring, a new breakaway box, and a water resistant junction box:
Also stole some of the new LED lights I have been hoarding:
Not sure which back up lights I will add, but it's down to these 2. Honestly will probably end up using the round as space is limited on the back end of the trailer. And it never had back up lights to begin with, so just any reverse light will be a HUGE improvement:
Also robbed a set of cube lights that I am thinking of adding to the top of the neck to add spot lighting to either side and the deck when needed.
And then I took a couple weld on D rings off the shelf so I can add a couple more tie down points.
Stopped at the local hardware store and picked up paint and the other necessary items to spray:
Along with new hardware for the decking. Decided to use good old carriage bolts instead of trying to mount from the bottom and risk boards loosening up over time, or the wood to metal self tappers that always break upon removal.
And also some new reflective safety tape:
Then I was going back and forth about building or buying fenders. I could use a set of drive over fenders, but ultimately I should really just purchase a deck over for the wider equipment. So I decided against that and was going to build a removable stock-ish set. But then during some late night online shopping, I found a set of new fenders for a price I couldn't pass up. So looks like I will be making some removable fenders out of these new beautifully rolled shells.
Brucker
Removed the remaining hardware that was rusted into place. An angle grinder with a cut off disc made quick work of them from both sides. No sense in leaving anything that could cut me later on. Then smoothed out the tops of the C channel with a flap disc to remove the rust. Was amazed how well the frame has held up after 21 years.
Looking at the hardware that was left:
Cleaned up:
And with the decking removed, I can finally look everything over. There are some things to repair, but overall, I am pretty happy with how well it's held up over the last 21 years.
There is a strap that ties the ramp holders together that is broken and needs welded up:
The back end of the frame is tearing apart on both sides:
And now I know why the wiring had been giving me issues. Besides the snap locks and the wire nuts, I found another junction box I didn't know existed. Thank goodness I am starting from scratch on the wiring....
Going to clean up the entire frame, not down to bare metal, but get any loose rust off and at least scuff up all of the shiny powder coating. Then I can hit the spots that need it with Eastwood's rust encapsulater spray and then a good primer over everything
Brucker
Scraped off the stickers from the frame the best I could and removed all of the lights.
Then spent some time cleaning up the frame with an angle grinder armed with a braided wire wheel. Again, not taking it down to bare metal if I can help it. But making sure to get all the loose materials and rust off and to scuff up the original powder coating so nothing shiny is left.
This is about when my back was screaming at me, and the pitting of the frame in some areas required me to take it down to bare metal. So since I will be having to primer the entire thing anyway, I decided to try a faster method (and easier on my back). I went and purchased a sand blasting pressure pot.
Harbor Freight was having a special on them so decided to give it a go. This is kinda an experiment as the reviews of these aren't great and many on Youtube state that they require modifications to make them work well. Guess I will find out for myself.
Brucker
Took a minute to get the sand blaster working properly with the media I wanted to use. But didn't need to buy anything special or modify the equipment in any way.
Media is expensive. Roughly $35-50 per 25 pounds depending on type. And although they state you can not use silica sand, that is more to with health concerns than anything. But if you wear the proper safety gear including a respirator, using sand shouldn't be an issue. And with playground sand being between $6-8 per 50 pound bag at your local home improvement store, it's a MUCH cheaper option. Plus it is environmentally friendly so clean up is easy with just a leaf blower. And with a project like this that requires a lot of media, it's the option I chose.
I messed around trying to get the setup to work with the playground sand straight out of the bag for about an hour. It would clog the system almost immediately. Could not get it to run consistently. Noticed there were actually large pieces of sand mixed within the bag. So I decided to try to screen the material through a standard sift. And that made all the difference! Even though not much got screened out. Out of 350 pounds worth of material, only filled a one gallon container with the pieces that were too large.
Clean screened material, about 200 pounds worth:
I managed to use the machine for about an hour and used about 150 pounds of screened media. Got the front neck section completed and went over a couple of the cross rails that were already wire wheeled but where the wheel couldn't reach. Coming clean much quicker.
Brucker
350 pounds of screened sand later, it is finished. Will need to clean up the fender areas still but will wait till the old fenders are removed. I decided to leave the aluminum toolbox where it was and will mask it off. There is a bunch of internal support that will need to be cut apart in order to remove it and It won't be worth the effort.
Brucker
Didn't get much accomplished over the weekend. I got to spend time with my father for Father's Day, so I am not too upset about not getting around to this project. But I did manage to get the wheels and tires off and then removed the existing, badly damaged fenders. Will clean up the areas well before I start on fabricating the new, removable fenders.
Brucker
I knew the fenders were going to be a problem area. Sheet metal welded to thicker C channel that created pockets for moisture to live the past 20 years. Good times.
What was left after removing most of the fenders:
Spent a good amount of time removing the old welds and all of the rust from both sides. There is a good amount of pitting, but nothing deep enough for me to worry about the overall structure of the c channel. Especially with the extra metal rails I will be installing with the decking.
You probably noticed a decent amount of flash rusting on the frame. We have had some decent storms roll through and there just isn't room in the shop for this project right now. So I will have to deal with it before I primer. But I have a ways to go before that. I did start on the fenders but I don't have the photos uploaded yet. Will update how that process is going soon.
Brucker
Waiting on a client so I thought I'd try to update this quickly. With the frame cleaned up I started to work on the fenders. I had no real plan other than wanting to create strong mounting areas for the fenders that incorporate lights, act as steps, and a place for the new bump rail to tie in to. I started by taking some measurements from the old fenders (height and width). Then decided upon some 2"x3" angle to use as the long runner for the back of the fender. Then laid out the frame for the new fender location and clamped the new shells into position.
Then took some measurements to figure out the mounting areas. I want them to match so I figured out everything based on the passenger side rear, where the access door for the steel ramps is located. This is what I came up with for the top plates. Not a fan a tread plate, but it does add traction to slippery areas, and since I know these will be used as steps, I used tread plate.
Then added a length of the same material I will use for the rub rail to make sure everything will line up as hoped.
Then, since the driver side front mount should be the same, I mocked that up.
ScaldedDog
Sedalia, CO/NSB, FL
Pardon me while I delete the photos I took of mine...
What impresses me most is not the quality of your work - I've seen your stuff, and have come to expect it - but how quickly you can do great work. "I've got 28.5 seconds while I wait for a guy to park his car. I think I'll whip up a fender."
Mark
Brucker
Mark
Thank you for the kind words.
Brucker
Really went back and forth over the rest of the mount. Was thinking of over complicating things and placing multiple lights within them. And making them the full 6" high that the c channel is. But in the end, I liked the shorter 5" high mount with a single turn/marker light. Simple and clean, while allowing for room to easily access the ramp door.
I started by making 3 more top plates for a total of 4:
Then cut out a plate to make up the rest of the boxed mount. This will be modified until it fits perfectly, but need to start somewhere:
Then bent it into the rough shape:
Then modified it to fit the fender and frame well and added the top plate.
And test fit the assembly:
You can see the to center marks I was planning to use to cut the hole out for the light. I didn't like where the light would be located once I mocked it up, so I added a paper cutout to get the placement where I was happy.
Just need make the three others, weld up the assemblies, and then weld them into place.
Brucker
Cut the remaining 3 plates into shape.
Bent them up and tack welded them together. Then shaped each of to fit into it's new home perfectly.
Then I welded them solid, smoothed out the exterior welds, then laid out the holes for the lights. When that was completed, I test fit them.
Brucker
The question I am still pondering, is which color lights to put in them. The fronts will get the amber turn/marker lights. But should the rear also get the amber? Or should I go with a red stop/turn/tail for more brake light visibility? I will be adding small round amber turn signals to the rear light setup. So would it look weird to have a red outside of an amber?
Leaning toward the red for more visibility... Thoughts?
