Nate
If anyone ever finds yourself rewiring your FJ40 with a Kwik Wire harness and you want to put it in the stock location, I designed a bracket you can run through a 3D printer. ***Full disclosure, it is currently printing and I have not assessed for fit*** 3mm thick and the hole location for the 40 and Kwik Wire mounts were designed with a combination of cardboard-aided design, micrometer, and Tinkercad.com.
Link here: https://www.tinkercad.com/things/aEPzXf8Cs08-fj40-to-kwik-wire-stock-location-bracket
