For Sale 2 compressors, 9.5” 80 series locker National Luna dual battery system and radius arms
mosdefjeff
Wheat Ridge
Well the 80 went under the knife and I’m officially set up with front and rear lockers with 5.29s and a new battery system. Threw on some Slee arms as well…this is what’s left…
Both compressors are single ARBs with all wiring. One was lightly used in my truck for airing up, no lockers. That one comes with a switch and a female air chuck, but you’d need a solenoid for lockers. The other was used for a single locker and has that solenoid attached with the older blue line, bulkhead fitting and tubing (ARB moved to more durable black line and different bulkhead fittings, full disclosure). It also has the Slee single compressor mount attached, but you’ll need a couple of nutserts and a tool (Amazon or Slee sell them) to make it work as well as an ARB switch. Mounts to the right of the brake booster on an 80, check Slees website for info: https://sleeoffroad.com/products/sok0026/
The locker is a clicker style locker (Aussie locker). I tore it out for an air locker but was told it isn’t too bothersome. Cheap option for one who doesn’t care or a dedicated trail rig.
The National Luna dual battery system will come with an OEM RH battery tray, but the Slee washer bottle bracket will be needed to make it work (https://sleeoffroad.com/products/sok1001/) Comes with wiring, fuses, solenoid and in-cab controller with linkable override for winching and low battery voltage alarm. Great, simple product. Installed in an 80 series, so all wiring lengths should be good to go for that application.
Compressors I figure are fair at $200/ea.?
Locker with carrier I’d let go for $150, I guess.
Battery system, I figure $300 is fair since I’m including the OEM tray?
Stock radius arms? Come and get ‘em. They’re just making my house heavier.
I’m negotiable to a certain degree. Only posted here for now. Wanted you gents to have a first go before it hits Facebook if things don’t move.
I’m interested in the dual battery setup. Thanks
I’ll take one of the compressors! Does one of them have the pressure switch still? I think the both look like they do I. The photos. I already have a bracket so the one without would be fine for me.
Will you be at the ralley?
mosdefjeff
Wheat Ridge
I won’t be at the rally, no. I’m in applewood.
I was mistaken…they both have pressure switches, but the one without the bracket will need an air chuck. The one with a locker solenoid has a standard switch with no provision for an air Chuck. I put that on my dual compressor
I’ll take the radius arms. Thank you!
Not sure if it needs to be mentioned or not and assuming youre replacing the bushings prior to installation.. but the orientation of the bushings on the arms is pre-TSB..Holes are now supposed to be front to back and not top to bottom.
put me second on the battery set up
mosdefjeff
Wheat Ridge
Good point. To my knowledge, those are original bushings.
damon
damn it. life got int he way of me spending too much time on the internet and I missed all this.
damon
