Locker Install Write Up
Not to be confused with a Canadian stocking cap, which is a toque.
I was also noticing that you didn't *seem* to have the 5 photo-per-post restriction, it seemed to be all one post. How did you do that?
I will assume that the pics are not attachments per se but rather links to pics stored elsewhere? I've always wondered how folks get the words or captions to go with pics rather than having all the words show up above the pictures and having to say "In pic 1 such and such", "In pic 2 blah blah" like I do. Then I figured it was because they were inserting/linking images from an outside server. Never tried it so I don't know for sure :confused:
AxleIke
AHHHH We have a winner!!!!
That must be why it worked for me. I am used to being on other sites where you host your pictures from another site, then link them in using tags.
So yeah, that is how i did it. Photobucket.
And the pretty lass who fetches it for you in the morning... is she a toque wench?
Older Land Cruisers like mine use shims, newer ones use a crush sleeve.
I hate crush sleeves. I use an aftermarket spacer and shim setup, like the early minitrucks and apparently like the older Land Cruisers if I read you correctly - and a dial-type torque wrench. Makes life easy come pinion seal replacement time, too.
FWIW, I ran the 100 ft./lbs. carrier bearing torque past Brian Ellinger (Front Range Off Road Fab) this last weekend when I saw him, he said he might go 50 ft./lbs., but he'd be concerned about spreading the carrier at 100. He knows ZUK and has some differing opinions (like, for instance, on backlash for a rock rig). So there are differing opinions out there, just sayin'.
AxleIke
tested it today...Works like a champ. Double locked is fun!
AxleIke
Sure!
47b7db00b3127cce985480468b1500000027108AbNWLJszZOA
47b7db00b3127cce985480470a2400000027108AbNWLJszZOA
47b7db00b3127cce985480430a2000000027108AbNWLJszZOA
47b7db00b3127cce985480448b1700000027108AbNWLJszZOA
and to keep with tradition, the WORST facial expressions ever whenever my face is in a picture!
47b7db00b3127cce9854804e8b1d00000027108AbNWLJszZOA
and another awful face:
47b7db00b3127cce9854804f0a2c00000027108AbNWLJszZOA
