Rivnuts anyone
Been trying to work these Rivnuts to get my tank in and all I have been able to do is make the hole bigger. I am going to take it to a shop in the morning unless someone out there is good with this stuff, or more likely has the right tool
From this thread. Two existing holes and two need to be drilled
http://george4wd.taskled.com/auxtank.html
what do you mean by 'work them"? are you installing rivnuts or are youdoing something to existing rivnuts?
I'm installing rivnuts to hang my sub tank
do you have the tool to install them?
no tool. went to napa and carquest and they didn't know what I was talking about. Trying to use two 12 mm wrenches like cdan said
i think i got it figured out now. we will see
Rivnets are normally installed with a special tool which expands them to the predrilled hole they are inserted to.
yes, but that tool won't fit in these locations. That is why I had to use a different method. Worked in 3 out of 4 rivnuts.:D
Good to hear; after I posted that up last night I was in my garage and remembered that I have a tool (there are several different brands, including "nutserts, etc.) and an assortment of inserts. Holler if you'd like to borrow it!
