ttubb
0
What is the consensus on high altitude timing on a stock 78 2F? Thanks, Terry
I found that having the 'ball' (timing mark) just at the edge of the window works best - so this is 'beyond' the pointer. If the engine speeds up as you twist the distributor, then you're advancing (rather than retarding) I jacked up my timing a lot and then drove to Nebraska once and it was spark knocking like crazy - so you can get too much.
If you have a combination distributor (one with vac adv. and vac retard) disconnect the retard side and put a vented cap on it (to let it breathe as needed, but keep dirt out). Then adjust the base timing ahead some until it's either hard to start the engine, or knocks - and then back it off.
I'm sure others have some other ideas here - so chime in.
Steve
Perfect tuning procedure!![]()
Steve
b) general answer: engines run efficiently between certain parameters of timing and fuel, and having the timing far advanced presumably causes incomplete combustion or the higher emission of some component that stinks more. Generally, for emission tests, you want to retard your timing, if you have it far advanced for performance reasons. This will help with HC. Dialing the distributor advance back a bit and upping the idle speed are the classic 'parking lot move' before you drive into the emission station.
I will be taking my 40 to get emissions as soon as I get a muffler for it. I have my timing advances to 16 degrees. Is is better for me to retard it to the standard 11-13 range for the the purpose of emissions? I will be giving it a valve adjustment before then too. I want to give it the best opportunity to pass emissions. What is the optimal retard/advance setting for passing emissions? Plus if I retard the timing, do I need to reset anything to the carb?
a) too much advance = harder to start because it's firing *before* TDC - causing the engine try to push the cylinder down before it has reached it's apex/zenith (TDC). A little of this is ok, which is why most engines run timing advanced from TDC. Too much of this causes this 'firing too soon' problem and hard starting.
I am just guessing here, but I have heard a rule of thumb is to take the 7 degrees BTDC that Toyota specifies and then add 1 degree for each 1000 ft of altitude. So for us, 7 + 5 = 12 degrees BTDC. I would try that (tell me if your exhaust smells any better!) and set your idle a little higher. I am not sure what the max idle RPM they set for emissions testing in Denver, but a little higher idle won't hurt you. If you wanted to bust out the vacuum gauge and set idle mix for max vacuum, I think that will give you the most efficient burn.
Help yourself for the emissions test - change your oil and plugs right before you test.
