I have a bolt that broke I need to weld a nut on and try and get it out. Yes I tried easy outs and reverse drill bits, have a whole new set of different kinds Not an urgent thing, but it got me thinking. Kurt helped me out the last time this happened and I was thinking this would be a great tool to have. I do have a spare slot in my garage 90 Amp sub panel (220 Amp main) so could add 220V outlet which I likely will do no matter what I do here. I already bought the 50A Breaker and socket, just need the wire.
I have been searching and reading for days
I get that the 220V have more power. I see ones that have dual 110 or 220V as able to go to help others out of needed. Being a Dad I do that a lot
I see that the MIG welders with the gas and gasless Flux capability are best for home use projects. Going the Gas route is much preferred due to less splatter, but gasless may be OK for quick small things.
From all the reading the best brands are Miller, Hobart and Lincoln
I see a majority opinion that the Millermatic 221 is probably all anyone doing home stuff would ever need
Yeah if I had a need for a lot of welding for me I would go get the Miller 221
At almost half the price is the Lincoln easy 180 and the Hobart 190, both 220V machines. The reviews indicate the Hobart is better as it has 2 more power settings and a slightly wider power range. The Lincoln seems to be better setup if you want to do a quick gasless weld (not clear on this). These are both half the price of the Miller 211
There are differing opinions on if the 180 or 190 is strong enough for all auto projects like working on the frame, sheet metal or even building a trailer frame. Though I did see one video review with a guy using the Lincoln 180 to build a trailer frame
They key things is what do I intend to use it for. The broken bolt for one thing, but I can easily get help with that. I don't really have anything on the agenda, but would like something that can build a trailer frame or work on the trucks, not build a bumper but be able to weld sliders on or stuff like that. See I really don't know what I am talking about
I do this a lot, get a bug, research and educate myself and sometimes pull the trigger and sometimes decide I don't need it. Though, having tools is always a good thing arg arg arg
I do intend to take a class as I have always wanted to learn how to weld, I just dont have any projects in mind at the moment. Since I am a believer in buy once cry once, If I get a welder I would want it strong enough to do what I ever I might want to do in the future.
I understand I can do it all with the Miller 211
I think I could do it all with the Lincoln 180 or the Hobart 190, but there are conflicting opinions on the internet if one or both are powerful enough
Then cutting the price in half again there are the 110V 140 MIG welders. What related to our hobby can you do and not do with those? I think Kurt used a 110V unit to help me with my bolt issue last time
Keeping an eye on Craigslist for used ones. Its interesting some are within $50 of a new one
So, please give me a 101 on what you can and cant do with a;
110V 140 Amp Welder
220V 180 Lincoln or 190 Hobart Amp Welder
220V 210 AMP (Hobart or Miller) welder
110V 140 Amp Welder
