60wag
- Joined
- Aug 23, 2005
- Messages
- 2,476
I’ve got a Stihl string trimmer for landscape work. It works pretty well but has been inconsistent. The engine runs great but the cutting string will sometimes be very fragile, as in it’ll break off even when cutting light grass. Sometimes its better and will cut the thicker weeds.
I finally got fed up with it and did a bit of research on the net. There are comments regarding “crowding” the cutter and which side of the arc to cut on, but the most common comment involves the moisture content of the string. So my experiment involved dropping the cutting head spool of string in a bucket of water for 8 hours and then trying it.
Wow, what a difference. I was able to attack the thick woody weeds without breaking the string. I went through a whole tank of gas only needing to bump the string a few times. Maybe this is common knowledge but I found the difference stunning. I’m wondering if the variability I found in the past was due to the humidity in the air when I chose to run the trimmer.
