DouglasVB
Now that my sweet roof rack is on the truck, I'm looking at putting a 2M antenna on the rack. Currently the rack is electrically isolated from the truck at two different points (rubber on the crossbar feet and rubber between the crossbars and the actual roof rack). I can ground everything with a couple wires but my reading on the internet makes me think that won't be enough to create a good ground plane for my 2M antenna. I'm also not really wanting to grind up my roof and weld on grounding straps at all four corners of the roof basket.
Here's a picture of the roof rack:
I'll be throwing lights up there soon as well. Both a 52" light bar (thanks super cheap Chinese manufacturers!) and several work lights.
The antenna that I definitely want to mount somewhere on my roof is a Browning BR-180. I'm also thinking of where to place my 5' tall Firestik CB antenna. That one probably should mount somewhere at the rear of the vehicle once I make a rear tube bumper and tire carrier just because it would be so darn massive mounted on the roof. I also *might* put an AM/FM antenna on the roof to get it out of the way of the passenger's views for photography purposes. Hopefully I can find a reasonable retractable antenna to put in the stock location though. In the future I also want to mount a 10M antenna somewhere on the vehicle although that won't be until sometime next year.
So... four potential antennas. 1) 2M, 2) CB, 3) FM/AM, 4) 10M.
My questions are:
My questions are:
- What do I need to do to turn the roof basket into a decent ground plane (in addition to the rest of the roof and truck) for my antennas?
- Where else should I be looking to mount antennas? As we've talked about before in this sub-forum, the front bumper is out
