So the 's 80 decided that it wanted to start running around winking at folks (the flirt) at night...Cute but needs to get fixed...
Anyway it is the PS headlight and I figured it just decided it was time to give up the ghost...Well, I futzed with it and it came on so it is not burnt out.
Figure the connector was just loose or something I button it all back up only for the 80 to start winking again. I pulled it back apart and sure enough when I reseated the bulb into the lense it came back on...WTF? So I squirt some dielectric grease on and things seem to be fine but nope out it goes. I can wiggle the wires etc. and nothing. Pop the bulb out and reseat it and it comes on
Rather than chase a gremlin I'm thinking about popping in the Slee harness that I bought for the LX into the 80 and see if that resolves the issue, somehow. Any thoughts from those that have installed the harness on whether that might do the trick or will I simply have a fancy harness and still no headlight?
