simps80
The older I get the more I find myself getting interested in things that are old.
been fighting an obsession with old coleman stoves for a bit now...
but now I'm really starting to enjoy good cast iron (old) .
it cooks very well when properly cared for.
I've found the old iron is significantly higher quality than the new iron. funny how that works across most things...
I am mid-process on restoring a couple old one's I found a long time ago.
they were pretty neglected. So I stripped them down. Stripped down you can really see the difference in the quality. A glass smooth texture is what you can find on some of the good pieces. It's no wonder when properly seasoned and cared for they are non-stick, even cooking machines!
Anyway,
Found this pre-merger Griswold #3 that's 1957 or earlier.
the Erie, PA Griswold plant was closed in 1957.
It's small but perfect for camping single or cooking eggs. I'm 3 coats in on the strip down and re-season process.
I'll cook some bacon and potatoes in it for a while until it really starts to build back into the shiny black well-seasoned iron it should be.
here's just after stripping off the old rusty crust and getting down to virgin iron as best I can:
56565
3 coats in on new seasoning, as said I'll switch to natural process by cooking from here:
griswold was sold then sold to Wagner in 1957 based in Sydney, OH...where this next one originated.
I like this Wagner for bacon. Again, it was pretty bad when I found it, so stripped it clean and am in mid-process of rebuilding the base seasoning. On both these old pieces stripping it down far enough yields the original tooling spirals from when these manufacturers took the time to make them as smooth as possible. pretty neat.
This one will take a while to build back up, but it cooks pretty well now as is without sticking.
I've got some lodge, which is US made, but the current stuff isn't like the old stuff. real rough pre-seasoning to cover the lack of finish cast work...still cooks pretty good though cause of that composite bed-liner seasoning they put on it...
Problem with the older stuff, like Griswold especially, is China actually has been making knock-offs since the 80's so now some of the older knock-offs look like the real thing until you strip off the grime and old grease and notice the casting is poor....
If I could afford it, I'd like to try out some of the new USA based manufacturers like
Field
https://fieldcompany.com/
and i really like this one:
http://www.stargazercastiron.com/
both have started making cast like the old companies did, smooth smooth finish, high quality casting.
I'll probably buy one of those field 10" at some point if I can justify it somehow
How bout anyone else?
Anyone got a strange hankerin' for cast iron?
I gotta kick this habit, it's getting weird
Anyway,
Field
