What kind of wiring do these need to replace stock housings? I searched on the model number in the picture but nothing seems to pop up.
Also are these for all 80 series? I think I know the answer but the grills are different so... Searching on other aftermarket lights seem to say 91-97 are the same but hopefully someone can confirm.
The low beams you could plug the ballasts into the factory plug, high beams i have the adapter to factory wiring. I’d recommend a simple 9006 relay harness for best function on the low beams (~$10). If you wanted to utilize the shutter in the projector, you’d just need a splitter off the high beam plug. I can walk you through everything.
