I've got a mystery noise after replacing the front shocks on the 2010 Tundra. Like a metal on metal 'pop' sound. It's the loudest when backing into a parking space while turning. Just one initial pop noise only. It's got to be either the front sway bar connection at the lower control arm or the upper or lower shock mounts. All components were installed correctly and to proper torque. I'm going to disconnect the front sway bar mounting bolts and let the bar hang loose to see if that is the culprit. I guess it could be the rear sway bar that I recently installed but the noise sure sounds like it's coming from the front.
Any other ideas or experiences with this type of sound?
