All,
I wanted to put together another Middle St. Vrain & Coney Flats run on Saturday August 8th. For those of you who haven't ran this trail before, the trail is located north west of Boulder off of the peak to peak highway (highway 72). The trail is actually two trails that connect to make a loop. Both trails have a little bit of everything including some light technical rock crawling, amazing mountain views and a decent water crossing. This run usually takes a good 4 1/2 to 5 hours to go all the way around depending on how long you play around at the Coney Flats water crossing and for lunch so please be prepared for that.
Rising Sun Calendar
https://risingsun4x4club.org/calendar/
Photos from 2018 run
https://risingsun4x4club.org/xf/threads/middle-st-vrain-and-coney-flats.26981/
Photos from 2019 run
https://risingsun4x4club.org/xf/threads/middle-st-vrain-and-coney-flats-2019.28299/
See link below to funtreks for more info.
https://funtreks.com/off-road-trails/middle-st-vrain-coney-flats/
For this trail I would suggest that your vehicle has at least a mild lift & 33" tires. Middle St. Vrain is moderately challenging but once we make the turn up Coney Flats it becomes more difficult.
I attached direction to the trail head from both Boulder and Longmont, depending on what side of town you are on. See ya then!
Meeting Time: 0830
Departure Time: 0900
Meeting Location: Middle St. Vrain Trail Head Parking lot
HAM Frequency: RS#3 --147.420
CB Channel: 14
Driving directions from Boulder:
https://www.google.com/maps/dir/Bou...d0ed0fdbff116!2m2!1d-105.5236993!2d40.1299301
Driving Directions from Longmont:
https://www.google.com/maps/dir/Lon...d0ed0fdbff116!2m2!1d-105.5236993!2d40.1299301
GPS: 40°07'47.8"N 105°31'25.3"W
Rising Sun Calendar
Meeting Time: 0830
CB Channel: 14
