Machine shop
I need a machine shop that can bore and tap out my lower control arms from 1” to 1.25”
Who do ya know that can help?
I even have the bit and tap.
J Kimmel
Glenwood Springs CO
I had some aluminum lowers shortened and it was cheaper and faster to send them to Wide Open Design. They cut mine about an inch and threaded deeper and turned around back to me in about a week.
Seems like shops that don’t do this often really have a hard time with it.
Lastresort576
oh no! does this mean the other arms are bent etc causing the death wobble?
No, but trying to see if going back to poly bushings on the frame side vs Johnny joints is the problem
A big enough drill press would work as well.
ChevyKeith
Golden CO
I suspect my drill press or one of my mag drills would handle it
If you want to come up and try it out I am fine with that.
Just let me know
I have some large equip too bridgeport and lathe but have not had time to get the 3 phase convertors set up
066wally
If the arms were straight it would be an easy lathe setup. Since they are bent they pose a work-holding problem. A slow drill should do the trick if you can find a way to hold the arms firmly. A large tap handle would be almost necessary too. I have some thoughts on how to hold the work and possibly a large enough tap handle.
tancruiser
Steamboat
I can do that for you if you want to ship them up to me here in steamboat. I will be in Denver on the 17th if you can wait.
@IoN6 is getting me taken care of
