You just ran Kane Creek which is rated 4 out of 5, and you did it open. So what if you spun a little.
we should be treading lightly. Pretty soon that line on the left won't be passable without a locker either.
FWIW, for all the supposed problems and issues with ARBs, I have had few.
Air, especially the mounting of the compressor, and the routing of the air lines, are the biggest variables. Easy to get right though.
Don't worry too much guys. This air locker had been in my FJ40 for about 14 years. It had seen a lot of abuse. It was my daily driver as well as weekend wheeler. I run a 2F /sm420 along with a Toybox down to 37" IROKs. That locker saw a lot of torque and a lot of miles. I think I put in around 170,000 miles before it gave up on the way to work one morning.
Bingo.Everyone can justify their own purchases.
auto locker guys will tell you how much money they saved and how good they are on the street, and how dumb it is to spend money on a selectable. Selectable guys will tell you how worth it the money they spent was, and how awesome they are, and how terrible auto lockers are.
As far as the ARB stuff goes:
ARB failure is only due to install plain and simple. Proper install = years of excellent use and no failure. Improper mounting of the solenoids will cause them to collect dirt and fail. Improper routing of the airline will allow it to hit hot things, and leak. Improper install on the oring clip or the wrong type of oil, or chipped gears will get the o rings.
I disagree with the "except this one time" statement. I know several guys running ARB's and only one has had issue, due to the fact that he was running the wrong type of oil. Everyone else has had zero issues, myself included. Not except this one time issues, but zero issues.
