AdamKFarmer
Hey all, quick question on what would you do. I rebuilt my transfer case a few years ago on my '82 40 (thanks Marco!!) but since then there is a slow and steady leak form the case. I replaced it with the paper gaskets from Cruiser Outfitters with no sealant. Previously there was a ton of orange sealant that I had to scrape off prior to this. I bought a new gasket kit and was planning on trying again, what should I do differently? I thought the Toyota way was always correct, but after having re-plumbed my mini-truck and having to use FIP to prevent water leaking I'm thinking this might be a similar situation. I was thinking of spraying the gaskets with that spray gasket material to make them tacky and hopefully having a better seal. Thanks in advance!
