Recommendations for Kinetic Recovery Rope? Maybe I need to add this to my equipment. I just have a couple of straps.
Are you sure the ARB is a tow strap and not a recovery strap?I have a couple of 20-foot Bubba Ropes. I'd say I actually use them more often than my static ARB tow strap. I also have 4-5 of their soft shackles. Not cheap, but I've never had a problem with them.
The ARB isn't a tow strap, it's a recovery strap - please forgive my incorrect terminology. Any time I'm doing some sort of dynamic pull (as is usually the case in the snow), I use the Bubba Rope. If I'm just gently pulling on a rig, then I use the ARB.Are you sure the ARB is a tow strap and not a recovery strap?
There's always been two main types of straps (both are flat woven).
One is made with polypropylene and does not stretch at all. This type may or may not have steel hooks in their eyes and are known as tow straps. You always slowly tension these and pull slowly the same as you'd do with chain.
The other is woven with nylon and does stretch. These are recovery straps. They can be tugged and work basically like the Bubba (or any kinetic) rope. Kinetic ropes are also nylon but are braided and elongate more. It's still not a good idea to go all Bubba crazy doing that, you want slow and controlled as much as possible but that jerk-bump is sometimes just the thing to unstuck someone.
You'd size a recovery strap like you do a rope, by dimensions. A 2" nylon strap designed to be dynamic will stretch more than a 3" wide one just like a 3/4" rope will stretch more than a 1" diameter one with a particular load.
To confuse things even more there do exist tow ropes, which are polypropylene like the straps and you would not use them dynamically either.
Watch your material. Poly is always tension slowly and use a slow, constant pull. Nylon can stretch so you can jerk them somewhat.
And no, I've never hooked up the Bubba Rope and subsequently gone Bubba on the skinny pedal. Slow and steady, unless a little jerk/bump is necessary.
Man, you use one wrong word, and look what happens...
I think I'll buy one of them ASR 1" ropes. Need to measure my regular go-to recovery strap for length. It seems like a good length. It's probably 20 feet long.
Careful with your word choices there, chief. Otherwise, Dave will be on you like...wait, nevermind...BTW, I also had an omission typo, meant no-stretch tow straps and ropes could be polyester or polypropylene.
You can make a 30' length into a doubled 15' but it's tough to make a 20' into 30' if you need it. That was my thought anyway. I ended up with a 7/8" x 30' for a 5,300 lbs truck since I already had a 2" x 20' web sling around. You can't really say 20, 30 or 40 feet is "the one" right length. Sometimes 20' is perfect, sometimes it's not. You make work whatever you have. Same with winch rope. You want enough but not too much or too little. So you throw a dart to pick something, spool it on and carry an extension just in case.What’s the consensus on 20’ vs 30’ rope?
"What else should I be?Careful with your word choices there, chief. Otherwise, Dave will be on you like...wait, nevermind...
Well, I took it personally, and it hurt. But, after a good cry in the bathroom and a few whiskeys, I feel much better now.That's only why I used your post, it wasn't personal but the terms do matter and are confusing.
"Of all the gin joints in all the towns in all the world, Ryland walks into this one."Well, I took it personally, and it hurt. But, after a good cry in the bathroom and a few whiskeys, I feel much better now.
All kidding aside, this is great info. The first recovery "strap" (and I use the term "strap" loosely here) I purchased was a cheapo $30 Amazon special. Luckily, I never used it, and took one of Matt Balazs' recovery skills courses shortly after buying it, which resulted in my quickly throwing the strap in the trash, where it belonged.
Absolutely true! Traceability, serialization, rating and testing to accepted specs and markings are all key indicators for quality manufacturers of gear you can trust.The great thing about Treaty Oak is all of their ropes are made here in the U.S and are fully rated with tags that specify load ratings.
