• RS MAY CLUB MEETING
Fix one thing, discover another.
fyffer
Trinidad, CO
Today
Fixed an issue with the Power steering, as per assist PCS pump protocol. Good
Overfilled the reservoir and noticed a leak, it came down overflow hose. Good
Noticed something to my leaf spring, Bad
Called ALCAN with an invoice number from previuos owner. They knew the spring build, including extra 300# weight in front. Good
Had to order a set, following some measurements, price. HURTS
During a previous excercise of knuckle rebuild. Discovered belly plate at risk coming off, as well as a missing nut to a greasable bolt to rear shackle. Fixed
The good thing, I rather discover it here at home than on a Trail.
All potentially disastreuos. GLAD I check
D'oh!
Been there more than once.
fyffer
Trinidad, CO
D'oh!
I believe that was presented in my description and doubt it’s the last time. Hope you don’t mind me sharing on the forum. It could possibly help someone else/ new to thouroughly inspect and not neglect underneath and around. Preventative measures that could save a lot of headaches, being elsewhere.
I’m confused.
When I say been there more than once, I mean I’ve had a few leaf springs break on me. That’s all.
Ahh bummer! glad you had an invoice number. hopefully they set you up right. I literally found a greaseable spring pin spare in the garage today, remind me your address via PM and I'll send it.
fyffer
Trinidad, CO
Thanks Marco
Appreciate the offer, but done and fixed. ALCAN springs ordered as well as OME Shocks and Steering damper. Much thanks to reciepts you provided.
Discovered couple other things (GOOD), that will be fixed but wont share that on here anymore (BECAUSE).
