Extended sway bar links questions 06 LX 470
CardinalFJ60
I want to get extended sway bar links for the LX...trail tailor? or other vendors? I mean, it's just a steel rod, right? also...should I extend the brake lines, I think yes. what say ye'?
Not sure if this would work, but i bought these for my 80.
I've always extended brake lines on any lift.
Shuksan
I have them on all 4 corners on my 100 series from Trail Tailor. Don't know of other options for the 100. My bushings and pads were worn, so it was time to replace anyways.
AlpineAccess
Loveland
I made mine, got some new bushings where it needed them and then cut my stock end links in half and extended them 1.5 inches with tubing welded on the outside.
I have slee SS brake lines which improved brake pedal feel. The shielding on my stock lines was super cracked anyway.
