For Sale (Crosspost from MUD) 1200 Mile Complete, Running, Drivetrain. 383 Stroker, NV4500, Marlin Toybox, 34MM Split Case
Danger Noodle
Divide, Colorado
As some of you may know, I just recently finished my 40, and I already am feeling like it is time for some changes, mainly in the suspension. I'm wanting to link the rear, but my driveline is too long to get any effective link system in there, so I am looking to change. My loss is your gain, I guess. I'm posting this as a feeler to see if anyone is interested in a drop-in driveline that is tested and known. You could even drive it before you decide you want it.
Anyways, specs. Everything has been 100% professionally rebuilt, I have all receipts in hand. The engine has been dyno tested, and I have complete specs on it. I currently have ~1200 miles on everything. You are getting a basically new drivetrain.
What you get:
Engine: SBC 383 Stroker.
-Sealed Power Pistons ( Don't remember how much it was bored over)
-Clevite Main Bearings
-Durabond cam bearings
-NEW Melling HD oil pump
-Comp Cam and lifters (I'll add a photo of cam card)
-Scat Cast Stroker Crank
-ARP Intake and Head Studs
-New Cast Aftermarket Vortec (062 spec) heads.
-NGK Plugs
- Proform Valve Covers
-Dual Plane Intake
-Holley Sniper 4150 EFI
-Holley Hyperspark Ignition and Distributor
-New High Output Alternator, Starter, A/C Compressor, Water Pump, Power Steering Pump.
-180 Degree Thermostat.
This engine is dyno tested at 400 HP & 450 TQ at 7,000 feet in elevation. It was built for torque, and the torque curve is really great from idle.
Transmission: 1999 GM K2500 NV4500 (5.61 first, synchronized)
-New 3rd gear
-New 5th gear
-Complete rebuild, all bearings, synchros, etc.
-Have ONLY run AMSOIL 75W-90 Synthetic gear oil in this case.
-OEM Shifter
Doubler : Marlin Toybox (# 009 or 600) 2.2:1
-Rebuilt by Georg @ Valley Hybrids.
-Marlin Shifter
Transfer Case: 34MM Idler Split Case (2.3: 1)
-Georg Twinstick Shifters
Centerforce clutch, with new OEM FJ40 Slave Cylinder
Holley In-Tank 255 LPH regulated fuel pump, with a massive chunk of Holley Hydramat.
Frostbite 3 core radiator
AA Jeep Conversion Long-Tube headers
New Severe duty fan and fan clutch (installed ~500 miles ago)
I have over 18K (With receipts) invested into this setup. I'm willing to negotiate, so if you are interested, let's talk! As an added bonus, you get an amazing crawl ratio out of this; I'm currently at 156:1.
Telly
Monument
This would be sweeter in my 1970 C10 short bed minus the tcase!
Centennial, Colorado
383 and an NV4500 is what I have in my 40 and it rides smooth at 75 on the highway with great pickup. Had my setup coming on 8 years and still very happy with it
Danger Noodle
Divide, Colorado
I do really like this setup. It cruises great on the highway and is plenty slow in the rocks. All the power you could really want. It's just a little too long in a 40.
Danger Noodle
Divide, Colorado
I'm also open to offers on just the toybox and splitcase if anyone is interested. I have someone questioning about it, but I would much rather keep it within the state if possible. Shipping can be a pain.
I didnt notice before looks like you have the front end single belt setup. I had to add that to mine after replacing a belt. with individual belts it was a real pain. I think that about $1000??
I am really happy with my setup. I havent found a short rear shaft to be a problem. In Fact I have an extra as I was troubleshooting a problem that turned out to be a damaged pinion
5th gear is smooth at easily due 80 with no issues
Danger Noodle
Divide, Colorado
Yep, I am running a serpentine setup from a 95 Serria 1500. My main concern with the rear shaft length is I'm wanting to link the rear, and I'm afraid I'm going to either run out of slip or start to max the joints, so I'd like to decrease the angle if possible.
:unsure: Would it be more cost effective to just start a new buggy build from scratch? ;)
