coarse spline front axle
Got a coarse spline drum brake front hub assembly from Ben, when I removed the Warn hub last night I couldn't figure out how to get to the wheel bearings - it looks like I might need a special 4-pronged wrench to loosen up the wheel bearing so I can remove it. Sound right to anybody?
not unless it's got some sort of chevy or ford nut on there. measure it, i might have the socket you need...i've got two different ones, one was for my old gmc, and one is for the ford/toyota hybrid setup i have on the back of the 68
