HoneyBadger
I've got an old 2007 CRF 230F that is having carb flooding issues.
When it was new, obviously it ran great for years.
But it's been sitting in my father in law's barn in Texas for the past 15 years.
I'm trying to get it up and running again.
I took apart the carb and cleaned it in a ultrasonic cleaner for an hour and a half.
I reassembled everything, put in a new spark plug, turned the fuel on, and she fired right up. It ran great. I rode it around for about 10 minutes and got it hot.
Then I turned it off. It seems that as soon as I turned it off, it just kept filling the carb with fuel. We tried to crank it back up about a minute after turning it off and it was already flooded. Fuel was gushing out of the airbox drain. So obviously this means that the fuel is not getting shut off in the carb and it's just continuously filling the bowl and back filling through the carb into the air box.
So we thought it may have to do with the jets being optimized for the near sea level market the bike was originally sold in. So I bought new jets for 8k-10k elevation optimization. I also replaced the rubber tipped needle valve on the floats, thinking that it may have been worn out and letting in fuel. The adjustment screw is turned all the way in, letting in as little fuel as possible.
So last night I put it all back together and turned the fuel on. It fired right up. Ran great. Rode it around for about ten minutes and got it hot. Turned it off and waited for about 10 minutes. Wouldn't start. Flooded. Killed the battery AGAIN trying to get it to start.
So I let it sit all night. I came in this morning and tried it again. It wouldn't start. Flooded to the point of gushing fuel out the air box drain again. The battery died again.
So I hooked it up to a jumper box and cranked and cranked and cranked it until after about 5 minutes of continuous cranking it FINALLY started up. Fuel still pouring out of the air box.
It never behaved like this years ago, obviously. I'm at a bit of a loss as to what to do next.
Have any of you had this type of issue? Is there something I'm not checking that needs to be cleaned/checked/replaced? Do I need to just say f**k it and buy a new carbonator?
