Three years ago my family picked up an 1979 FJ40 Landcruiser over the mountains. Car is still stock. To start it had a lot of problems, started but just barely and had a massive coolant leak from the water pump. Took a few weeks when we first got it to get it running, new water pump, belts, fuel filter, and cleaned the carb.
After getting it running I drove it for the summer between highschool and college but after that it just sat for a while because no one else wanted to drive it. So this summer when I moved out of on campus housing I took it and have since been working on getting it running better. Fixing the old 2F engine has been tough though. Fixed a massive exhaust leak (although there is still one on the smog part connected to the air injection that's going to require a new gasket) new sparkplug and wires, and fixed a vacuum leak to the distributor. Car sounds and feels much better now, however there are still some issues that need fixing that I was curious if anyone else had run into these issues and knew anything about them. When coming to a stop in neutral sometimes the car will stall out, seems to only happen after running for a while on high rpm's but recently it has been doing it all the time. Constantly have to mess with or flutter the choke to keep it from dying. Currently the 2F engine is as it was from the factory, but I'd like to desmog it, although I'm not sure I can with Colorado laws. I'm hoping fixing that the gasket will fix some of that but I'm not sure it will. Anyone else run into this issue and found any fix for it?
