Burt88
I've worked under both platforms and could never tell a difference in the suspension configurations after the Lexus AHC is removed. Is there something unseen?
Reason I ask is because I have been denied a Bilstein warranty based on their opinion that the shocks are not compatible on the LX470. The shock kit in question is the Landcruiser specific set of four 5160's for up to 2.5" lift. The identical set that is available through Slee and other suppliers. I installed 2 inches of lift and in less than 10k miles the stem broke at the upper mounting position. Reason's for denial of the claim are; improper installation using an impact wrench, damage during installation, and that they were installed on the wrong vehicle. I can assure everyone that they were installed properly, due to the fact that you can't fit anything but a hand wrench where the upper nut is. The only thing I noticed between the Bilstein and others is a lack of adequate bushings for the mounting angle. I only assumed the engineers have a handle on those sorts of things.
I'm not trying to get a single shock replaced at this point, just trying to figure out what the major difference is between the 2 platforms.
