ccslider
My truck is acting weird, only when the weather is cold, not the engine cold but the ambient temperature. I drove it to arvada this morning from broomfield and it was acting up during hard throttle. I just drove it at lunch and its running fantastic.
When it hits 3k rpm at full throttle it will act like its being starved for fuel. Bucking, hesitation. Light throttle it will accelerate fine. Neutral revs fine. My truck is Supercharged, has good vac at idle -15 / -20 or so.
I ordered a fuel pressure tester but it wont be here until Saturday.
Stuff i've done / checked.
changed the plugs NGK copper 4844 colder for supercharger, old ones looked carbon fouled
replaced cap / rotor, had some wear
replaced wires, 2 were close to being out of resistance spec
oem fuel filter
Checked the harness by egr, I had previously wrapped it / secured away from tube.
Checked timing with light
no codes
TPS is showing proper range on scan gauge of 12-88%
Idle is perfect
Newer o2 sensors
checked for vac leaks
did the wiggle test on wires and connectors
head gasket was done 25k ago
I was thinking maybe an injector is sticking, at idle i could hear each one firing. Im trying to think of something that is shrinking with the cold but I'm drawing blanks here.
oem fuel filter
no codes
Idle is perfect
Newer o2 sensors
land cruiser miss
youtube.com
