DariDesilva
I have a 1991 Land Cruiser LJ78G with 5-speed manual trans and 2LTE engine for sale. The LC is in immaculate condition. New paint in original blue-gray, the interior is in great original condition, with a new head unit with Apple car play/Android, and new speakers, sounds great. The inside/outside temp and altimeter were replaced with two dials with turbo boost, temp, battery voltage, EGT, and oil pressure. 4x4 works great with the new manual front hubs. Everything in the LC works as expected. Electric door locks, electric windows work as expected. Electric mirrors work but not perfect. It also had a reverse camera. It has new Mickey Thompson 265/65R17 tires, and new wheels with a perfect offset (5 new tires and wheels). The speedo is accurate. no lift. The LC has zero rust anywhere (including under carriage, under doors, fender wells, etc). The 2nd and 3rd row seats have original carpeted mats. All seats, carpeting, door panels, headliner is very clean and nice. The LC has 269k KM (167k miles). It runs very well. It bought it because it was in fantastic original condition, and I made it a lot better. Emissions is due in December 2020, and it passed without issue in Colorado.
The 2L-TE original head was replaced 5k miles ago with a complete 3L head from Australia, along with the water pump, gasket kit, timing belt, pre-tentioner (a long list of replacements). It misfires for 20-secs during a cold start. It starts up immediately with no issues, 2nd start of the day onward. It has no issue keeping up at highways speeds at 110-120 kmph (65-70mph), at around 3000 RPM. 1st gear to 20km, 2nd to 40, 3rd to 60, 4th 70-80, then to 5th. I usually go at 110-120km on the highway.
I will add many more pix in the next couple days.
All fluids were replaced Oct 2019. The engine oil and Toyota oil filter (90915-30002) was replaced Oct 2020.
Engine. 2L-TE
Turbo. CT20
5speed transmission: 150F
New Parts:
Timing belt Idler assy: 13503-54030
Timing belt tensioner pulley; 13505-54021
Timing belt: 13568-129MR31
Value cover gasket: 11213-54050
Water pump, gasket and studs: 16100-59257
Engine overhaul Gasket Kit: 04104111-5410411-54104
GMB NFC82 fan clutch
Complete brand new 3L head sourced from Australia with new cam, valves, etc. with warranty
The diesel injectors were rebuilt by Odd Iron Offroad in Georgia
new injector washer kit
new fuel return manifold pipes are new
new Toyota diesel filer
new Toyota air filter
new temp shield on underside of hood
new OEM dash radio surround (55413-90K00)
New OEM key (90999-00212)
New Hella made Toyota horn set
New front manual hubs
New Batteries
I have a new weather stripping for the windshield, but I have not gotten it installed to avoid breaking the original windshield.
Please call or text me at 720-233-4280 or email daridesilva@gmail.com. Thank you
Engine. 2L-TE
Turbo. CT20
New Parts:
New Batteries
