3FE Head, manifolds, fuel rail, injectors
Colorado Springs
I have a freshly built head with oversize SS valves, new springs, etc never installed. Plus the full set of hardware in the description for $500.
Sounds good and thanks for the reply. I’m thinking it over.
Colorado Springs
As I was taking pictures I realized I had only installed half the valves so I'm including my complete valve hardware collection along with a height micrometer so you can finish the job. I also realized I had Robbie do some work on the valve bowels to un-shroud them so it should flow better than stock. I should have also mentioned I hand picked the springs from several new sets to match them for height under load.
Also there are two sets of standard 3FE injectors, all were ultrasonically cleaned and flow tested with new pintle covers installed ( some people refer to that as "rebuilding", I consider that abuse of the language though)
